Normal Topic Installing to toolbox in VS 2013 (Read 3255 times)
David Long
Oct 15th, 2014 at 9:26pm
I've just upgraded from VS 2010 to VS 2013 and I am having problems adding MindFusion controls to the toolbox.  I can add them using drag and drop from Windows Explorer, but the controls are all disabled (greyed out).  I am using version 5.3.5 of Diagramming for WinForms (Pro).  My application targets .NET 3.5
Any help gratefully received.
David Long
Re: Installing to toolbox in VS 2013
Reply #1 - Oct 16th, 2014 at 10:58am
You should drag assemblies from the "VS2008 (.NET 3.5)" folder if your project's target framework is .NET 3.5. I can see grayed controls when I drag assemblies from "VS2010 (.NET 4.0)" folder.
David Long
Reply #2 - Oct 16th, 2014 at 1:20pm
This is what I did.  I have tried again and I still get greyed out controls.
David
Reply #3 - Oct 17th, 2014 at 10:53am
It works in my test. Try removing all old mindfusion.* items from the toolbox or using the Reset Toolbox command from context menu before dragging again, in case there's conflict with a different version of the assemblies you had dragged earlier. Alternatively try adding the controls using the Choose Items menu command.
David Long
Reply #4 - Oct 18th, 2014 at 9:27pm
This works OK if the target framework is .NET 4. If it's .NET 3.5 it does not work. (Screenshot attached) I guess I could change my application's target framework everytime I need to add a control - not ideal, but it is a workaround!
David Long
David Long
Reply #5 - Oct 19th, 2014 at 10:39am
I have found the solution by looking back at an issue I had bookmarked some years ago...
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=129225448...
This solves the problem. Lucky I had bookmarked it - I don't think it is still possible to search back that far.
David
