Normal Topic Large margins inside container after layout (Read 2246 times)
Michael K
Dec 16th, 2014 at 7:34am
I am just getting started with the Diagramming components. I have a set of nested diagrams, using the Decision layout. I build the layout recursively, innermost child first, then layout the parent etc.
I find that there is a large margin in the container nodes - how can I reduce this? I have tried setting the layout.Margin = new SizeF(0, 0).
See attached picture.
Here is how I layout each container, once the nodes and links have been added: (items contains the nodes and links for the container)
Code (C++)
DecisionLayout layout = new DecisionLayout();
layout.Margins = new SizeF(0, 0);
layout.StartNode = firstNode;
layout.Arrange(testCaseDiagram, items);
Re: Large margins inside container after layout
Reply #1 - Dec 16th, 2014 at 9:10am
Try setting container's AutoShrink property and calling its UpdateBounds method after arranging the container's children. That should wrap the container around its children.
Michael K
Reply #2 - Dec 16th, 2014 at 9:13pm
great, thank you, adding .AutoShrink = true solved the issue.
