Normal Topic how to save Font's porperties to xml and read from XML file? (Read 1596 times)
heyx
Jan 5th, 2015 at 3:27am
hi,
I override the methods that SaveToXml and LoadFromXml but I find that error always occurs when Save the FontStretch and the FontWeight perporty in debug. could you please give me some help? thanks.
  protected override void SaveToXml(XmlElement xmlElement, XmlPersistContext context)
	     base.SaveToXml(xmlElement, context);
             context.WriteObject((object)FontWeight, "FontWeight", xmlElement);
	     context.WriteObject((object)FontStretch, "FontStretch", xmlElement);
             context.WriteEnum(FlowDirection, "FlowDirection", xmlElement);
             context.WriteFontFamily(FontFamily, "FontFamily", xmlElement);
             context.WriteDouble(FontSize, "FontSize", xmlElement);
             context.WriteFontStyle(FontStyle, "FontStyle", xmlElement);
             context.WriteBrush(FontBrush, "FontBrush", xmlElement);
             context.WriteBrush(Brush, "Brush", xmlElement);
             context.WriteEnum(TextAlignment, "TextAlignment", xmlElement);
             context.WriteEnum(TextVerticalAlignment, "TextVerticalAlignment", xmlElement);
         protected override void LoadFromXml(XmlElement xmlElement, XmlPersistContext context)
             base.LoadFromXml(xmlElement, context);
             FlowDirection = (FlowDirection) context.ReadEnum("FlowDirection", xmlElement);
             FontFamily = context.ReadFontFamily("FontFamily", xmlElement);
             FontSize = context.ReadDouble("FontSize", xmlElement);
             FontStretch = (FontStretch) context.ReadObject("FontStretch", xmlElement);
             FontStyle=   (FontStyle)context.ReadFontStyle("FontStyle", xmlElement);
             FontWeight = (FontWeight)context.ReadObject("FontWeight", xmlElement);
             FontBrush=   context.ReadBrush("FontBrush", xmlElement);
             Brush = context.ReadBrush("Brush", xmlElement);
             TextAlignment = (TextAlignment)context.ReadEnum("TextAlignment", xmlElement);
             TextVerticalAlignment = (AlignmentY)context.ReadEnum("TextVerticalAlignment", xmlElement);
Re: how to save Font's porperties to xml and read from XML file?
Reply #1 - Jan 5th, 2015 at 2:44pm
Font attributes are saved by base DiagramItem class, you shouldn't have to save them yourself. WriteObject will work only for serializable types, and DiagramItem uses WPF's converters to get a string value and pass it to WriteString:
object fontWeightValue = ReadLocalValue(FontWeightProperty);
if (fontWeightValue != DependencyProperty.UnsetValue)
	string stringVal = new FontWeightConverter().ConvertToString(fontWeightValue);
	context.WriteString(stringVal, "FontWeight", xmlElement);
object fontStretchValue = ReadLocalValue(FontStretchProperty);
if (fontStretchValue != DependencyProperty.UnsetValue)
	string stringVal = new FontStretchConverter().ConvertToString(fontStretchValue);
	context.WriteString(stringVal, "FontStretch", xmlElement);
