Normal Topic Diagram - Create Image and Diagram Bounds and BackgroundImage (Read 2643 times)
steini
Jan 27th, 2015 at 1:30pm
I'm new here to this forum.
I have a problem with the diagram/diagramview control and a few properties.
For example i set a backgroundimage (e.g. size = 1920*1080):
diagram.BackgroundImage = image;
diagram.BackgroundImageAlign = ImageAlign.Stretch.
Now i set the bounds of the diagram to the size of the image.
diagram.Bounds = diagramView.ClientToDoc(new Rectangle(0, 0, image.Width, image.Height));
The problem is, if i want to create a image from the diagram control, the returned image height and width is 1px smaller than the original image (1919 * 1079).
var image = diagram1.CreateImage();
Do you have any ideas how to get this fixed?
I need the exact same size from createimage.
Thanks.
Re: Diagram - Create Image and Diagram Bounds and BackgroundImage
Reply #1 - Jan 27th, 2015 at 4:24pm
Try calling diagram.CreateImage(diagram.Bounds, new Rectangle(0, 0, image.Width, image.Height), 100);
steini
Reply #2 - Jan 28th, 2015 at 8:09am
Thanks a lot, that solved the problem!  Smiley
