Normal Topic In TabbedDiagramView, I have to right-click a node before I can delete it with Del key. (Read 2445 times)
Centron
Mar 5th, 2015 at 11:01am
As the title says. Steps to reproduce:
- Have a default TabbedDiagramView named diag in the UI:
<diag:TabbedDiagramView Name="diag" />
- In the designer code-behind, add to the constructor:
        public MainWindow()
            InitializeComponent();
            diag.Document = new DiagramDocument();
- At runtime, add a page to the document via the + button.
- Draw the default rounded rectangle, select and try to delete with Del key. It doesn't work.
- Select a rectangle and right-click anywhere in the diagram, then it can be deleted with the Del key.
- If you right-click and then select a new node, it again cannot be deleted until you right-click beforehand.
Is there any workaround to this behvaiour? Am I missing something?
Re: In TabbedDiagramView, I have to right-click a node before I can delete it with Del key.
Reply #1 - Mar 5th, 2015 at 1:58pm
The template of the TabbedDiagramView contains a ScrollViewer, which prevents the diagram from receiving focus when the user clicks with the left mouse button. This can be circumvented by setting the Focusable property of the ScrollViewer to false. You can reach the ScrollViewer from any DiagramPage object by crawling up the visual tree. For example, you can do that when a new page is added to the document via the '+' button:
diag.PageAdded += (s, e) =>
	e.DiagramPage.Loaded += (s1, e1) =>
		var parent = VisualTreeHelper.GetParent(e.DiagramPage);
		while (parent != null && !(parent is ScrollViewer))
			parent = VisualTreeHelper.GetParent(parent);
		if (parent is ScrollViewer)
			((ScrollViewer)parent).Focusable = false;
An alternative approach would be to replace the entire ControlTemplate of the TabbedDiagramView with a copy of the original template where the Focusable property of the ScrollViewer is set to false.
I hope this helps.
Centron
Reply #2 - Mar 5th, 2015 at 3:12pm
Thanks, that works.
