Normal Topic Dragdrop Shape on ShapeNode (Read 2415 times)
Thunis
May 18th, 2015 at 7:05pm
Hi Support,
How would I go around to only replace the Shape for a ShapeNode if I drag and drop another ShapeNode from the NodeListView onto the ShapeNode on the diagram? I don't want to create another node with the drag drop action only replace the Shapes for the Nodes.
Thunis
Re: Dragdrop Shape on ShapeNode
Reply #1 - May 19th, 2015 at 7:13am
Handle the Diagram.PreviewDrop event like this:
if (e.Data.GetDataPresent(typeof(DraggedNode)))
	var data = (DraggedNode)e.Data.GetData(typeof(DraggedNode));
	var position = e.GetPosition(diagram.DocumentPlane);
	var shapeNode1 = diagram.GetNodeAt(position) as ShapeNode;
	var shapeNode2 = data.Node as ShapeNode;
	if (shapeNode1 != null && shapeNode2 != null)
		shapeNode1.Shape = shapeNode2.Shape;
		e.Effects = DragDropEffects.Copy;
		e.Handled = true;
Thunis
Reply #2 - May 19th, 2015 at 11:23am
Thanks - Work 100% Cheesy
