Hot Topic (More than 10 Replies) TreeLayout (Read 13325 times)
Silvia88
TreeLayout
Sep 24th, 2015 at 1:40pm
how can I select the nodes that must partecipate in a treeLayout? I want to create a TreeLayout among a specified set of nodes.
Re: TreeLayout
Reply #1 - Sep 24th, 2015 at 1:58pm
You can pass diagram.getSelection().getItems() to arrange(DiagramItemList) overload if user will also select the links. Otherwise you will have to loop over all selected nodes and collect the nodes and links programmatically.
Silvia88
Re: TreeLayout
Reply #2 - Sep 24th, 2015 at 2:06pm
Sorry but it doesn't work, because method arrange wants a Diagram and not a DiagramItemList
Re: TreeLayout
Reply #3 - Sep 24th, 2015 at 4:53pm
Ok, this overload is not available for TreeLayout. It only lets you arrange subsets of the tree by specifying the branch' root node via TreeLayout.setRoot method. Depending on what you are trying to do:
- call arrange from a loop, each iteration using next selected node as a root
- or find the common ancestor of all selected nodes and set it as a root, calling arrange a single time.
Silvia88
Re: TreeLayout
Reply #4 - Sep 25th, 2015 at 11:44am
Ok, thank you very much Smiley
The problem is that I have a list of nodes and I want to create a tree(or something similar) only among these nodes, but if I use a tree layout it takes all nodes present in the diagram while I want only the nodes belonging to the list to be part of the tree. I have the nodes in this list:
List<ShapeNode> treeNodes where the node at the second position must be the root, how can I create a treeLayout only among these nodes?
Re: TreeLayout
Reply #5 - Sep 25th, 2015 at 3:51pm
Set that second node from list as TreeLayout.Root, and also enable the KeepRootPosition property so the layout does not move it, but only the children. If the nodes are already connected with links, TreeLayout should arrange them under the root then without modifying the rest of the tree. If there are child nodes that should not be arranged, you could set their IgnoreLayout property.
Silvia88
Re: TreeLayout
Reply #6 - Sep 25th, 2015 at 4:09pm
I did it but it doesn't work, by setting ignoreLayout to true it simply draws it in a different way but still connect the node that should be ignored, I want the node that should be ignored to be connected to the root of the layout and not to other node.
Silvia88
Re: TreeLayout
Reply #7 - Sep 25th, 2015 at 5:13pm
I solved the problem, I manage it in a different way and now it does what I want, thank you anyway Smiley
Silvia88
Re: TreeLayout
Reply #8 - Sep 28th, 2015 at 1:54pm
sorry but I have another problem with tree layout, I have something like in the attachment, I called method setText on the bigger link but it wrote the text, (Text) in the example,  in rect1 while I want to write it in the middle of the bigger link.
Re: TreeLayout
Reply #9 - Sep 29th, 2015 at 9:11am
If that arrow shape is a DiagramLink instance, try setting a different LinkTextStyle via DiagramLink.setTextStyle method, or alternatively use LinkLabel objects, which give you more control over positioning.
If it's a ShapeNode with a custom shape, you might have specified a text region that's above the main graphics. In such case remove the text region definition from Shape constructor and the control should use the graphics outline for text too.
Silvia88
Re: TreeLayout
Reply #10 - Sep 29th, 2015 at 9:57am
Ok, thank you very much, I used LinkLabel and it works.
But is there a way to take the length of the arrow headShape?
Because I want to put the label just under the arraow, like this:
Re: TreeLayout
Reply #11 - Sep 29th, 2015 at 3:25pm
Call the getHeadShapeSize method to find the default size, or setHeadShapeSize to set your own size.
Silvia88
Re: TreeLayout
Reply #12 - Sep 29th, 2015 at 3:36pm
Thank you very much Smiley
Silvia88
Re: TreeLayout
Reply #13 - Sep 30th, 2015 at 5:42pm
Hi, is there a way to know if a node belong to a TreeLayout?
Because I need to know it when I load the diagram from a saved file
Re: TreeLayout
Reply #14 - Sep 30th, 2015 at 6:19pm
There's nothing built-in to keep track of nodes processed by TreeLayout. You could mark them as processed by setting their Tag property from some recursive function you call starting with TreeLayout.Root node:
void markProcessed(DiagramNode node)
    node.setTag(true);
    for (DiagramLink link : node.getOutgoingLinks()) // or incoming depending on tree direction
        markProcessed(link.getDestination()); // or getOrigin
