Normal Topic ShapeControlPoints are not displayed when they are added to an already displayed ShapeNode (Read 2941 times)
Cyrinael
Aug 10th, 2016 at 12:55pm
I want to add ShapeControlPoints to a ShapeNode that is already displayed, but they only appear after the Node is stretched or completely new added to the diagram. I already tried to Repaint (shapeNode.Repaint(true)) and Invalidate the Node, but that didn't help either.
Is there another function that forces the Diagram to display the ShapeControlPoints when they are added?
Best regards,
Cyrinael
Online
Re: ShapeControlPoints are not displayed when they are added to an already displayed ShapeNode
Reply #1 - Aug 10th, 2016 at 6:13pm
Assigning the shape back to the node seems to work -
private void OnNodeClicked(object sender, NodeEventArgs e)
	var node = e.Node as ShapeNode;
	if (node != null)
		var shape = node.Shape;
		shape.ControlPoints.Add(
			new ShapeControlPoint("p5",
				50, 0, 100, UnitType.Percentage,
				20, 0, 100, UnitType.Percentage) { MaxXRelativeToWidth = true });
		node.Shape = shape;
Cyrinael
Reply #2 - Aug 11th, 2016 at 5:05am
Hi Slavcho,
that works well. Thank you!
Best regards,
Cyrinael
Cyrinael
Reply #3 - Aug 12th, 2016 at 7:39am
Hi Slavcho,
The control points are now correctly added, but now I have the problem, that with the re-assignment all changes I have done to any other ShapeControlPoint are reverted.
Best regards,
Cyrinael
Online
Reply #4 - Aug 12th, 2016 at 8:58am
Build from last post (https://mindfusion.eu/_beta/wpfdiag341.zip) also adds a ShapeNode.UpdateShapeControlPoints() method, call it instead of reassigning the Shape property.
Cyrinael
Reply #5 - Aug 12th, 2016 at 9:47am
Hi Slavcho,
you are correct. Thank you!
Best regards,
Cyrinael
