Normal Topic Overlapping links will cause the link text to disappear and sets strokeThickness to 1 (Read 2864 times)
Cyrinael
Aug 11th, 2016 at 9:38am
I have found a problem, where when two or more links completely overlap, the link text is not shown and the StrokeThickness is set to 1. The following code will show the problem:
ShapeNode node1 = new ShapeNode() { Bounds = new Rect(10, 50, 20, 20) };
ShapeNode node2 = new ShapeNode() { Bounds = new Rect(80, 50, 20, 20) };
ShapeNode node3 = new ShapeNode() { Bounds = new Rect(150, 50, 20, 20) };
diagram.Nodes.Add(node1);
diagram.Nodes.Add(node2);
diagram.Nodes.Add(node3);
DiagramLink link1 = new DiagramLink(diagram, node1, node2);
link1.StrokeThickness = 5;
link1.Text = "Test";
DiagramLink link2 = new DiagramLink(diagram, node1, node3);
link2.StrokeThickness = 5;
link2.Text = "Test";
diagram.Links.Add(link1);
diagram.Links.Add(link2);
Maybe the removal of the text is intended, but the stroke thickness should not switch when the Links overlap in my opinion.
I attached the images of the result.
Best regards,
Cyrinael
Online
Re: Overlapping links will cause the link text to disappear and sets strokeThickness to 1
Reply #1 - Aug 11th, 2016 at 10:52am
It seems related to the links being horizontal rather than overlapping, because the same happens if you rearrange the arguments a bit -
DiagramLink link2 = new DiagramLink(diagram, node2, node3);
I guess that's related to the bounding rectangle of link's UIElement having 1-pixel height originally, and this staying cached somewhere in diagram's or WPF code, leading to thicker line and text getting clipped. Our developer will investigate.
Cyrinael
Reply #2 - Aug 11th, 2016 at 11:42am
Hi Slavcho,
the same thing happens also with vertical aligned nodes
Best regards,
Cyrinael
Online
Reply #3 - Aug 11th, 2016 at 1:16pm
Hi Cyrinael,
This build should fix it -
https://mindfusion.eu/_beta/wpfdiag341.zip
Best regards,
Cyrinael
Reply #4 - Aug 12th, 2016 at 6:08am
Hi Slavcho,
the strokeThickness is now correct. Thank you.
Best regards,
Cyrinael
