Normal Topic An error while loading from xml (Read 6090 times)
Gravity
Oct 7th, 2016 at 1:20pm
I am getting an error when trying to load from xml
Code (Javascript)
    var xmlUrl = "http://localhost:1234/template.xml";
    diagram.loadFromXml(xmlUrl, OnSuccesfulXmlLoad, OnErrorLoadingXml);
An error:
Code (Javascript)
return p.attributes.getNamedItem("Id").value||"RoundRect"}
and p.attributes.getNamedItem("Id") is null
Well i using custom shape node and custom diagraming link they are described in template.xml like 'ns:MyCustomNode' and 'ns:MyCustomDiagramingLink'
well they are plain empty. What i have declared is:
Code (Javascript)
var MyCustomShapeNode = function (parent)
	AbstractionLayer.initializeBase(MyCustomShapeNode, this, [parent]);
MyCustomShapeNode.prototype =
     // i have these line removed, since samples not using similar init/disp.
    //initialize: function () {
    //    AbstractionLayer.callBaseMethod(this, 'initialize');
    //dispose: function () {
    //    AbstractionLayer.callBaseMethod(this, 'dispose');
What could be wrong?
Re: An error while loading from xml
Reply #1 - Oct 7th, 2016 at 1:29pm
Is template.xml a file created by Diagram.saveToXml and could you attach it here?
Gravity
Reply #2 - Oct 7th, 2016 at 2:08pm
Slavcho wrote on Oct 7th, 2016 at 1:29pm:
Sure, but the problem is not in xml file, because i load the same in webforms it works just fine. It is more like i can't figure out something.
p.s. i've attached file, just rename to *.xml
template.txt (Attachment deleted)
Gravity
Reply #3 - Oct 7th, 2016 at 2:24pm
more on this line:
where p is "LinkHeadShape"
Gravity
Reply #4 - Oct 7th, 2016 at 2:32pm
If i add Id attribute to <LinkHeadShape> tag, then i get error: Item classId ["ns:CustomNode"] is not registered.
which happens here:
Code (Javascript)
instantiateItem:function(s,p){var q=this.diagram.xmlClassMap[s];if(!q){throw new Error("Item classId ["+s+"] is not registered.")}
i have registered them like so:
Code (Javascript)
$(document).ready(function () {
    AbstractionLayer.registerClass(CustomNode, "ns:CustomNode", MindFusion.Diagramming.ShapeNode);
    AbstractionLayer.registerClass(CustomLink, "ns:CustomLink", MindFusion.Diagramming.DiagramLink);
Reply #5 - Oct 10th, 2016 at 6:28am
This xml file is in some ancient XML format of ours, have you used older ActiveX or Windows Forms version to save it? We've added XML serialization in JavaScript library only recently and current official build works with latest format #17 of XML files, yours is <Diagram Version="12">. It happens we've just implemented some backwards compatibility for a client, it seems it can also load your template.xml file as well -
https://mindfusion.eu/_beta/jsdiag271.zip
The build above officially supports versions as old as 13 though, we'll check what differences there are from 12 to it.
WebForms version already has backwards compatibilty in its .NET LoadFromXml implementation, then it sends contents to client side as JSON.
The second parameter of that registerClass method is not XML id but fully qualified type name (with added namespace). It doesn't seem we offer public API to register XML identifiers for custom classes directly in JavaScript. For time being you could implement that by replacing following function in Diagram.prototype with your version that adds new identifiers -
var Dictionary = MindFusion.Collections.Dictionary;
registerXmlTypes: function ()
	var xmlClassMap = new Dictionary();
	function register(ctor, classId, classVersion)
		xmlClassMap[classId] = ctor;
		ctor.xmlInfo = { classId: classId, classVersion: classVersion };
	register(mdiag.DiagramLink, "std:DiagramLink", 2);
	register(mdiag.ShapeNode, "std:ShapeNode", 1);
	register(mdiag.TableNode, "std:TableNode", 1);
	register(mdiag.ContainerNode, "std:ContainerNode", 3);
	register(mdiag.SvgNode, "std:SvgNode", 2);
	register(mdiag.FreeFormNode, "std:FreeFormNode", 1);
	register(mdiag.GlassEffect, "std:GlassEffect", 1);
	register(mdiag.AeroEffect, "std:AeroEffect", 1);
	return xmlClassMap;
Gravity
Reply #6 - Oct 10th, 2016 at 9:54am
Thanks, that is very helpful.  Can you elaborate a bit more one diagram prototype declaration?
This is how i am currently declaring:
Code (Javascript)
 Diagram.prototype = {
    registerXmlTypes: function () {
        function register(ctor, classId, classVersion) {
        register(mdiag.ShapeNode, "ns:CustomNode", 1);
        register(mdiag.DiagramLink, "ns:CustomLink", 1);
        return xmlClassMap;
  AbstractionLayer.registerClass(Diagram, "Diagram", MindFusion.Diagramming.Diagram);
  AbstractionLayer.registerClass(CustomNode, "CustomNode", MindFusion.Diagramming.ShapeNode);
  AbstractionLayer.registerClass(CustomLink, "CustomLink", MindFusion.Diagramming.DiagramLink);
  diagram = AbstractionLayer.createControl(Diagram, null, null, null, $("#diagram")[0]);
After this code line registered <...>registerClass(Diagram, <..> i am getting an error "Out of stack space"
To what it could be related?
Reply #7 - Oct 10th, 2016 at 10:26am
Set it like his -
Diagram.prototype.registerXmlTypes = function() ...
and do not remove the standard class registrations but only add your two lines after them.
Gravity
Reply #8 - Oct 10th, 2016 at 10:50am
Slavcho wrote on Oct 10th, 2016 at 10:26am:
Set it like his -
Hm, that did not helped : / same result. Chrome says Uncaught RangeError: Maximum call stack size exceeded
and IE says Out of stack space, i guess the same error, can't really see where it is happening. I think it is even before calling registerXmlTypes methods, i added to registerXmlTypes console.log lines...
Another question, new version of jsDiagramming will be with backwards XML comparability ?
Reply #9 - Oct 10th, 2016 at 12:22pm
Attached modified sample seems to load the file successfully, using 2.7.1 build from above.
Samples.zip (Attachment deleted)
