Normal Topic Negative Coordinates (Read 2026 times)
38Mikes
Feb 22nd, 2017 at 10:14pm
I'm having a few issues related to negative coordinates on the diagram.  I am able to create nodes in negative terrain (ie, negative in the X or Y or both X and Y quadrants), but I cannot move them.  If I grab a node and drag it to another position, it will move while I'm holding down the mouse button, but if the final resting place is in a quadrant with a negative axis after letting up the mouse it will just snap back to previous location before moving it.  I also have the problem that when I add nodes to the negative space the scroll bars don't appear on the view box.  But scroll bars do appear if I add things in the positive quadrant...
Re: Negative Coordinates
Reply #1 - Feb 23rd, 2017 at 8:16am
Set Digram.Bounds to a rectangle that includes the coordinates you intend to use, e.g. new RectangleF(-400, -400, 800, 800).  To let users draw new nodes outside of that area and automatically adjust the scroll range, set AutoResize to AllDirections.
