Hot Topic (More than 10 Replies) add a custom property for ShapeNode (Read 10435 times)
kelum
Apr 28th, 2017 at 5:08am
In mindfusion how to add custom ShapeNode property ?
Ex: add following property
ID
Name
Type
Re: add a custom property for ShapeNode
Reply #1 - Apr 28th, 2017 at 8:37am
Id and Name properties are already available, derived from DiagramItem and FrameworkElement respectively. Name is not serialized by built-in code though. You can add custom properties like Type as shown in IconNodes, Tutorial 3 & 4 sample projects.
Another approach without creating custom node class is shown in SiteMap sample project - it defines properties in a separate class and assigns its instance to standard ShapeNode's Tag property.
kelum
Reply #2 - Apr 28th, 2017 at 9:49am
can you give the direct link for "Tutorial 3 & 4 sample projects." ?
Reply #3 - Apr 28th, 2017 at 10:00am
If you've run the diagram's installer you can find sample projects under C:\Program Files (x86)\MindFusion\MindFusion.Diagramming for WPF\Samples\Source code\ folder. You can also download individual sample projects here -
http://mindfusion.eu/wpf-diagram-samples.html
kelum
Reply #4 - Apr 29th, 2017 at 8:38am
in tutorial 3 and 4 i cant find places where its adding new property ? can you specifically mention the places I need to change to add a new custom property to this shapenode ?
Reply #5 - May 1st, 2017 at 5:46am
You can find Title, FullName and Image properties created in OrgChartNode.cs. Also check the help topic here -
http://www.mindfusion.eu/onlinehelp/wpfdiagram/index.htm?CC_Tutorial_3__Create_a...
kelum
Reply #6 - May 2nd, 2017 at 3:40am
Actually I'm trying to add new property for `ShapeNode` not to Create a Custom Node Type ?
is that possible to add new property for `ShapeNode` ? if yes, can you give reference or please mention it step by step
Reply #7 - May 2nd, 2017 at 5:37am
You could either add your properties to a struct and assign its instance to node.Tag as shown in SiteMap example, or use WPF attached properties -
https://msdn.microsoft.com/en-us/library/ms749011(v=vs.110).aspx
kelum
Reply #8 - May 2nd, 2017 at 5:42am
okay I wish to follow this path `add new properties to a struct and assign its instance to node`
can you mention steps it with a sample ?
Reply #9 - May 2nd, 2017 at 5:52am
See https://mindfusion.eu/samples/wpf/diagram/SiteMap.CS.zip
It defines a PageProps structure in MainWindow.xaml.cs and keeps there values that must be associated with nodes. You can see Tag assigned in OnNodeCreated handler. If you need the custom values saved in XML, also check SerializeTag and DeserializeTag handlers.
kelum
Reply #10 - May 2nd, 2017 at 7:55am
is it possible to initiate this property once this ShapeNode adding to shaplist in constructor ?
public LayoutWindow()
InitializeComponent();
shapeList.Items.Add(new ShapeNode { Bounds = new Rect(0, 0, 50, 50), Tag.NewProperty = NewPropertyValue});
Reply #11 - May 2nd, 2017 at 8:39am
Try something like this -
new ShapeNode
    Tag = new MyTag { NewProperty = NewPropertyValue },
kelum
Reply #12 - May 2nd, 2017 at 8:58am
but then that Node Property not listing under following method
for (int i = 0; i < 2; i++)
var node = diagram.Factory.CreateShapeNode(90, 100 + i * 70, 60, 30, Shapes.Rectangle);
node.RotationAngle = 45;
//This is not listing
node.Type = "NewTypeValue";
for list under CreateShapeNode
do I need to do following ?
    [Serializable]
    internal class ShapeNodeCustomProperties
        internal string NewProperty { get; set; }
    ShapeNodeCustomProperties newprop = new ShapeNodeCustomProperties();
     for (int i = 0; i < 3; i++)
          newprop.Type = "NewTypeValue";
          node.Tag = newprop.Type;
Reply #13 - May 2nd, 2017 at 9:04am
It's a property of the tag structure and not of the node, you will need to set your custom values through Tag -
node.Tag = new MyTag { Type =  "NewTypeValue" }
kelum
Reply #14 - May 2nd, 2017 at 9:06am
okay thanks Smiley is this need to serialize and de-serialize also ?
