Hot Topic (More than 10 Replies) Node anchor points are out of place (Read 10295 times)
tadeus
May 12th, 2017 at 12:01pm
Hello!
I create programmically gateway node and links connected to that node. And have this result:
This result occurs only when I create links from code.
Thanks, Tadeus
Re: Node anchor points are out of place
Reply #1 - May 12th, 2017 at 4:58pm
Have you actually set nodes' AnchorPattern property? See the Anchors.js example, link creation seems correct there.
tadeus
Reply #2 - May 23rd, 2017 at 8:21am
Yes AnchorPattern is set. Problem is only when I use destNodeLink.setDestination(gateway) method.
Reply #3 - May 23rd, 2017 at 9:07am
By gateway node do you mean one of custom node type, or it's a standard ShapeNode with BpmnInclusive shape set? What AnchorPattern value have you assigned to it?
tadeus
Reply #4 - May 23rd, 2017 at 9:23am
It is standart node:
case ShapeType.InclusiveGateway:
this.Shape = Shapes.BpmnInclusive;
this.Brush = new MindFusion.Drawing.SolidBrush(Color.White);
this.Pen = new MindFusion.Drawing.Pen(Color.Black, 1);
this.EnabledHandles = AdjustmentHandles.Move;
this.HandlesStyle = HandlesStyle.EasyMove;
break;
There is anchor pattern:
var gatewayAnchorPoints = [new AnchorPoint(50, 0),
new AnchorPoint(100, 50),
new AnchorPoint(50, 100),
new AnchorPoint(0, 50)];
Thanks!
Reply #5 - May 23rd, 2017 at 1:39pm
That's ASP.NET code for custom node type constructor?
tadeus
Reply #6 - May 24th, 2017 at 5:04am
Yes it is ASP.NET.
Reply #7 - May 24th, 2017 at 5:31am
Creating them from server or client -side code?
tadeus
Reply #8 - May 24th, 2017 at 5:47am
All is created from server.
Tahnks.
Reply #9 - May 24th, 2017 at 10:00am
Here we've ported our AnchorPoints sample project to ASP.NET -
https://mindfusion.eu/_samples/AnchorPoints.ASP.NET.zip
Note it defines custom AnchorPattern on both server and client sides; at this time only the pattern ID is JSON-serialized along with nodes so you need the definition on both sides.
tadeus
Reply #10 - Aug 23rd, 2017 at 12:47pm
Slavcho wrote on May 24th, 2017 at 10:00am:
I create gateway and link from client side, but this code dont work correctly:
var gateway = new DLXShapeNode();
        gateway.setBounds(
            new MindFusion.Drawing.Rect(
                destNode.bounds.right() - 140,
                destNode.bounds.center().y - 20,
                40,
                40)
        var gatewayAnchorPoints = [new AnchorPoint(50, 0, true, true),
                                new AnchorPoint(100, 50, true, true),
                                new AnchorPoint(50, 100, true, true),
                                new AnchorPoint(0, 50, true, true)];
        var gatewayAnchorPattern = new AnchorPattern(gatewayAnchorPoints);
        gateway.setAnchorPattern(gatewayAnchorPattern);
        gateway.setShapeType(ShapeTypes.InclusiveGateway);
        diagram.addItem(gateway);
        // get first created destination node link
        var destNodeLink = destNode.incomingLinks[1];
        destNodeLink.setDestination(gateway);
        var connectionLink = new DLXDiagramLink(diagram, gateway, destNode);
        diagram.addItem(connectionLink);
        destNode.incomingLinks[0].setDestination(gateway);
Reply #11 - Aug 24th, 2017 at 8:43am
The constructor and addItem calls alone seem to attach to anchor points -
We'll investigate why setDestination does not - try removing it for time being, or if you need to change destination to a different node, call setDestinationAnchor too.
tadeus
Reply #12 - Aug 24th, 2017 at 11:37am
Slavcho wrote on Aug 24th, 2017 at 8:43am:
Thank you!
Gravity
Reply #13 - Sep 7th, 2017 at 10:16am
I see problem here in a usage. setDestination function takes two arguments (destination, anchorpoint)
If second parameter not set it use already created parameters "details")
Gravity
Reply #14 - Sep 7th, 2017 at 1:05pm
Gravity wrote on Sep 7th, 2017 at 10:16am:
My question would be why setDestination function does not attach to anchor point?
Code (Javascript)
    gateway.setAnchorPattern(gatewayAnchorPoints);
destinationNode.incomingLinks[1].setDestination(gateway, gateway.getAnchorFromIndex(1));
diagram.routeAllLinks();
This kindof place link at correct anchor point, but does not attach to it. Maybe you would know why?
