Hot Topic (More than 10 Replies) Node anchor points are out of place (Read 10248 times)
Gravity
Re: Node anchor points are out of place
Reply #15 - Sep 7th, 2017 at 1:53pm
Gravity wrote on Sep 7th, 2017 at 1:05pm:
Gravity wrote on Sep 7th, 2017 at 10:16am:
I see problem here in a usage. setDestination function takes two arguments (destination, anchorpoint)
If second parameter not set it use already created parameters "details")
My question would be why setDestination function does not attach to anchor point?
Code (Javascript)
   var gatewayAnchorPoints = [new AnchorPoint(50, 0),
        new AnchorPoint(100, 50),
        new AnchorPoint(50, 100),
        new AnchorPoint(0, 50)];
    gateway.setAnchorPattern(gatewayAnchorPoints);
destinationNode.incomingLinks[1].setDestination(gateway, gateway.getAnchorFromIndex(1));
diagram.routeAllLinks();
This kindof place link at correct anchor point, but does not attach to it. Maybe you would know why?
In documentaiton i can find "ReassignAnchorPoints" method, but can't find it in source...is this something that ought to be?
Reply #16 - Sep 8th, 2017 at 7:49am
link.setDestination(node) should now attach to anchor point with this version -
https://mindfusion.eu/Forum/YaBB.pl?num=1504852763
If you also want to specify the anchor point explicitly, you could call link.setDestinationAnchor(1);
