Normal Topic Visio Import library beta tests (Read 4779 times)
Aug 8th, 2005 at 3:21pm
A second beta build of the Visio Import library is now available for download here:
https://mindfusion.org/_beta/visio2fcx.zip
It fixes a crash that happened when importing Visio Entity Relationship diagrams.
To try it, unzip the file and use regsvr32.exe to register the FcxVisioImport.dll. The library requires installation of FlowChartX Pro.
The component's progID is "FlowChartX.VisioImporter". At this time the library can import Visio 2003 VDX file (Visio XML Drawings). Visio 2002 files are not supported.
Soon we'll start beta tests for an Export library that creates VDX files from FlowChartX drawings. Stay tuned.
Re: Visio Import library beta tests
Reply #1 - Aug 15th, 2005 at 11:08am
We have uploaded a new build of the Visio import library beta version, it is available for download here:
The new dll fixes a bug which made the size of imported diagram elements incorrect when using some of the Visio measure units.
Reply #2 - Aug 27th, 2005 at 3:31pm
A new build has been uploaded here:
The import process has been optimized greatly, now importing works much faster!
The API has been changed as follows:
- ImportVDX methods removed
- GetPageCount method added
- ImportPage method added
- ImportAllPages method added
These allow importing specific pages of the Visio document.
strong_peng
Reply #3 - Nov 7th, 2007 at 1:19pm
how to use importallpages
virtual /* [helpstring][id] */ HRESULT STDMETHODCALLTYPE ImportAllPages(
           /* [in] */ BSTR vdxPathName,
           /* [in] */ IDispatch __RPC_FAR *flowChartDoc,
           /* [retval][out] */ VARIANT __RPC_FAR *Result) = 0;
how to get flowChartDoc?
i have FlowChart m_FlowChart;
could you give me a example.
Reply #4 - Nov 7th, 2007 at 1:43pm
If FlowChart is an MFC wrapper class, you can get an IDispatch pointer like this:
IUnknown* pUnk = m_FChart1.GetControlUnknown();
IDispatch* pDisp = NULL;
hr = pUnk->QueryInterface(IID_IDispatch, (void**) &pDisp);
if SUCCEEDED(hr)
     importer->ImportAllPages(strPath, pDisp, &varResult);
