Normal Topic Populate boxes from database (Read 4350 times)
shanker
Guest
Aug 23rd, 2005 at 1:12pm
I have a requirement to show processes in graphical manner which connects to different process like successors and predecessors. How to do that, please suggest
Re: Populate boxes from database
Reply #1 - Aug 23rd, 2005 at 2:38pm
FlowChart.NET does not provide automatic data binding, so you will have to create ADO.NET datasets from your process and relation tables; then enumerate the records in the datasets and create a Box instance for each process and Arrow instance for each relation.
Do you already have a database schema describing the processes and relations or it's yet to be designed ?
In the general case there would be a many-to-many relationship between the processes, which you could present using an auxiliary table. E.g. if the main table is
Process
title: text
details: text
then implement the relations as
ProcessRelations
successorId : foreign key to [Process]Id
predecessorId : foreign key to [Process]Id
It should be easy to map that schema to a FlowChart.NET diagram. At the end you would have to arrange the nodes and links, by either setting directly the BoundingRect and ControlPoints properties or using one of the automatic layout routines provided.
