Normal Topic Share Image Solution (Read 4232 times)
suwit
Guest
Aug 20th, 2005 at 4:09pm
Is it posible to use share resource image, this is to save memory. like in GoDiagram product from Northwood?
Re: Share Image Solution
Reply #1 - Aug 22nd, 2005 at 7:47am
Shared images are not supported at this time. Use custom drawing to achieve the same effect, i.e. load the image once, and in the DrawBox event use the Graphics.DrawImage method to display the same image in each box.
