Normal Topic how to know who is my parent and child of an arrow (Read 4857 times)
Mah
Guest
Aug 27th, 2005 at 12:16am
let say, i create 2 box and link them with an arrow. Then how i gonna to output the answer actually this arrow is linking with the 2 boxes?
how to identify it with a unique identity?
coz i plan to save the path and boxes value into database.
Iva
Re: how to know who is my parent and child of an a
Reply #1 - Aug 27th, 2005 at 10:33am
I am not sure I understand your first question:
- if you need to determine which two boxes are connected by a specific arrow, use the Arrow class' Origin and Destination properties.
- if you need two determine whether two boxes are linked in a specific direction and want to find the arrow that links them, use the boxes' IncomingArrows and OutgoingArrows collections, e.g.:
Arrow getLink(Box b1, Box b2)
  foreach (Arrow link in b1.OutgoingArrows)
    if (b2.IncomingArrows.Contains(link))
     return link;
  return null;
Iva
Reply #2 - Aug 27th, 2005 at 10:38am
Regarding assigning uniquie identifiers to diagram items, use the Tag property to store these IDs. E.g.
box1.Tag = createUniqueID()
Here createUniqueID() is your function that creates GUIDs or other kind of identifiers. Later you can use the FindBox method to search for a box by its ID.
Assign the ID to a box after you create it programmatically, or in a BoxCreated event handler for boxes created interactively by the end user.
