Normal Topic Undo and redo (Read 4054 times)
mah
Guest
Undo and redo
Sep 7th, 2005 at 2:30am
I am trying to do a events for undo and redo
FlowChart1.UndoManager.UndoEnabled = True
FlowChart1.UndoManager.Undo()
above is my code, but it wont works, anyone can help me on that?
Iva
Re: Undo and redo
Reply #1 - Sep 7th, 2005 at 5:05am
FlowChart.NET starts creating undo/redo records for modifications done on a diagram after your set
UndoEnabled = True
But then if you immediately call
UndoManager.Undo()
there isn't any record created yet, so nothing is undone. If you want to use the undo/redo functionality, set UndoEnabled somewhere in your application initialization code (e.g. a Form constructor or OnLoad handler), so FlowChart.NET record modifications from the very beginning.
