Normal Topic Can't create new boxes in parts of the FC (Read 2657 times)
Mary
Guest
Sep 26th, 2005 at 11:54am
I have set the behavior of the flowchart to be "bhFlowChart", thus allowing the user to create new boxes on the fly.  In the documentation it says:
If the operation cannot be completed at current mouse position, the cursor changes to a crossed out circle.
This happens to me when the user is drawing away from the upper right part of the flowchart.
What property controls where the user can draw?  Does it have to do with the current layout type?
Thanks for any help.
Re: Can't create new boxes in parts of the FC
Reply #1 - Sep 26th, 2005 at 2:26pm
Probably the document size it too small, try setting a larger one like this:
fc.DocExtents = new RectangleF(0, 0, width, height)
or enable the AutoSizeDoc property so the document will resize automatically when users draw objects outside its current area.
HTH
Mary
Guest
Reply #2 - Sep 26th, 2005 at 3:28pm
Thanks!  It was the AutoSizeDoc that I needed.
