Normal Topic Node + label and layout (Read 3106 times)
Mike
Guest
Oct 14th, 2005 at 3:40am
I'm dynamically drawing a graph (node at a time, redrawing on each update) that needs an icon + label for each node.  To do i create two boxes, and attach them together using AttachTo.
However, when I call Arrange on the graph, they get separated.
Is there any way I can group items together so they act together as a single node?
Although I could use a table I dont really want to as it changes the look/feel.  Custom drawing he node seems a bit like overkill.
Cheers.
Re: Node + label and layout
Reply #1 - Oct 14th, 2005 at 4:31am
Set the label boxes' IgnoreLayout property to true so the layout routines dont' change their position, and the labels will just stick to the icon boxes.
All layout classes have a KeepGroupLayout property which does something similar, and now I see we forgot to mention it in the docs. You might try that instead of InoreLayout.
The difference between the two methods is that KeepGroupLayout makes a group treated as an integral graph node and includes in its size the sizes of all included boxes, while with the IgnoreLayout method only the size of the icon boxes would be considered.
HTH
mike
Reply #2 - Oct 14th, 2005 at 5:14am
Stoyo, you da man!  spot on, and I'm amazed in how quick you posted an answer Smiley
A great library - well worth it.
Cheers,
Mike
Reply #3 - Oct 14th, 2005 at 8:19am
Thanks  Grin
