Normal Topic TreeLayout partial arrange. (Read 3145 times)
Pascal
Oct 13th, 2005 at 12:50am
I'd like to have 2 differents way of arrange, depending of the node type.
This a sample code:
if (node.Type == a)
   _boderLayout.Root = node.Box;
   _boderLayout.Arrange(_control);
else
   _centralizedLayout.Root = node.Box;
   _centralizedLayout.Arrange(_control);
This code doesn't work.
It's always layout everythig and not from the root node I specified. Don't know why.
Thanks.
Pascal.
Re: TreeLayout partial arrange.
Reply #1 - Oct 13th, 2005 at 7:43am
The tree layout will arrange everything if you set null as root. Please check wheter the node.Box is really set to some box. If you use groups as tree nodes, set as the root a group's master node; a subordinate one won't work.
Pascal
Reply #2 - Oct 17th, 2005 at 11:08am
Sorry I didn't had a chance to reply before.
I found it, I had to IgnoreLayout to true.
Thanks for your reply
Pascal.
