Normal Topic Mouse move event for Boxes and arrows (Read 2281 times)
DongJoKim
Oct 28th, 2005 at 2:17am
Hello.
My question is:
How can I generate an event when the mouse is move(or over) a box or arrow?
I'm almost sure that this is possible, but I havent found the event that could do this.
Iva
Re: Mouse move event for Boxes and arrows
Reply #1 - Oct 28th, 2005 at 5:09am
You might do something like this sample from the MouseMove help topic:
Private Sub fc_MouseMove(ByVal docX As Long, ByVal docY As Long)
  Dim obj As Object
  Dim b As box
  'get the object under the mouse pointer
  obj = fc.ObjectFromPoint(docX, docY, True, False)
  If obj Is Nothing Then
    'clear the status bar message
    statusBar.Panels(1).Text = ""
    Exit Sub
  End If
  'if it is a box ...
  If TypeOf obj Is box Then
    b = obj
    statusBar.Panels(1).Text = b.UserString
  End If
End Sub
It uses the ObjectFromPoint method to detect what diagram item is under the mouse and updates the statusbar text accordingly.
