Normal Topic Can't export to visio (Read 6699 times)
lemon
Oct 28th, 2005 at 9:51am
Hallo back  Wink
Why is the following code wrong?
MindFusion.Diagramming.Export.VisioExporter exp;
exp.Export(_flowChart, "C:\\file\\FlowChart.vdx");
Error: System.NullReferenceException
thx for support
Iva
Re: Can't export to visio
Reply #1 - Oct 28th, 2005 at 10:26am
It seems 'exp' is not initialized. Try with this
MindFusion.Diagramming.Export.VisioExporter exp = new MindFusion.Diagramming.Export.VisioExporter();
lemon
Reply #2 - Oct 28th, 2005 at 10:36am
thx.
Now I have no error. But also no file in my folder  ???
Iva
Reply #3 - Oct 28th, 2005 at 10:45am
There is a 'VisioExport.vxt' file that must be in the current directory when exporting. It contains an empty Visio XML document, which the exporter fills in with the diagram data. Make sure that file is in the application's current directory or where the exe is.
There was a bug that prevented the exporter find the template file in some situations:
http://mindfusion.org/cgi/Forum/YaBB.pl?board=fcnet_disc;action=display;num=1129...
We fixed that and sent patched versions to registered customers, but the trial version is not fixed yet.
lemon
Reply #4 - Oct 28th, 2005 at 11:32am
No I doesn't work
We have got the new dll Version (18.Oct)
I create a .vtx file with visio and put it in the exe directory and in \bin
I  tryed to export my vds.file to \bin -> nothing
and than to exe dir -> nothing
What's wrong
Iva
Reply #5 - Oct 28th, 2005 at 11:36am
You should not create that file with Visio but use the one provided with FlowChart.NET. It is located in \Program Files\MindFusion\FlowChart.NET, just copy it to the folder where the .exe file is located.
lemon
Reply #6 - Oct 28th, 2005 at 12:37pm
hi
I can't open the new file in visio without losing informations
I have exported the flowchart in vdx. Wrong format?
Iva
Reply #7 - Oct 28th, 2005 at 1:53pm
Hi, What information is lost exactly ?
lemon
Reply #8 - Oct 28th, 2005 at 2:36pm
Hallo
e.p.
the forms from the nodes
the font(arial) looks not like in FC
Iva
Reply #9 - Oct 28th, 2005 at 3:07pm
Do you use custom shape definitions in your application ? At this time only the predefined Flowchart.NET shapes can be exported. If some of the predefined shapes are not exported, can you let us know their IDs or upload a diagram file here so we check them ourselves:
http://mindfusion.org/cgi/HelpDesk/index.php
Thank you
