Normal Topic Improve performance when saving to database (Read 3641 times)
Espen Lodden
Guest
Nov 7th, 2005 at 12:25pm
we are evaluating the FlowChart .NET and have trouble when saving to an Oracle database stream.  Loading from the stream works fine, and does not take long time (although it's not fast). Saving however, takes ages. Saving a diagram with two nodes took more than one minute. Is there anything we could do to improve this?
Excerpt from our code follows:
OracleCommand cmd = new OracleCommand("", conn);
OracleDataReader reader;
OracleLob lob;
OracleTransaction txn = conn.BeginTransaction();
cmd.CommandText = "SELECT schema FROM test WHERE id = 1 FOR UPDATE";
cmd.Transaction = txn;
reader = cmd.ExecuteReader();
reader.Read();
lob = reader.GetOracleLob(0);
//This function is VERY slow
_flowChart.SaveToStream(lob);
txn.Commit();
dl.disconnect(conn);
Best Regards
Espen Lodden
www.emisoft.com
Re: Improve performance when saving to database
Reply #1 - Nov 7th, 2005 at 12:51pm
Thank you for trying FlowChart.NET.
Saving speed has been greatly improved in the version 4 of the control, which is now in beta tests:
https://mindfusion.org/_beta/FCNetDemo.zip
Although if two nodes are saved for a whole minute, that might mean that the OracleLob Stream implementation is slow. Try calling the flowchart's SaveToString method to measure how much time is needed to save the diagram in a memory buffer,  and then write the returned string to a Text/Memo field.
Or check whether the Oracle stream has some option to preallocate space for the diagram instead of growing the field dynamically several times. I guess writing to the OracleLob can be very slow also if the Oracle stream uses network communications to access the database without buffering. FlowChart.NET will write many small chunks of data to the stream, so calling SaveToString and then sending the whole string to the Oracle server could be the best solution.
Best Regards
Espen Lodden
Guest
Reply #2 - Nov 7th, 2005 at 1:05pm
Thank you very much for the quick reply. We will try your suggestions.
Best Regards
Espen Lodden
Espen Lodden
Guest
Reply #3 - Nov 7th, 2005 at 1:28pm
Thanks a lot,
saving to a string and using byte array to the database worked like a charm. Less than a second.
This is very promising!
Espen Lodden
Reply #4 - Nov 7th, 2005 at 1:38pm
That's great!
But then SaveToString uses 4 times more space than a byte stream would need, because every byte is represented with 2 Unicode characters in the string. So in order to save some space, it will be even better to create a .NET MemoryStream, pass it to the SaveToStream method, and pass the memoryStream's bytes to the Oracle stream.
