Normal Topic PaintBackground event (Read 2204 times)
andy
Nov 9th, 2005 at 8:20pm
is there a PaintBackground event or something like that? Can't find anything that would help... I'm using a class to do the painting (mainly backgrounds) to support themes. Pretty much like the ToolStripProfessionalRenderer class in .net 2.0.
If I don't want to paint everything by myself I can't use the Paint event though as it overdraws elements.
Any ideas? I'd appreciate it... thanks heaps.
Cheers,
Andy
Re: PaintBackground event
Reply #1 - Nov 10th, 2005 at 5:03am
There isn't any such event. You might try setting the flowchart's Brush, used to paint the background, to a texture or gradient brush.
If that won't do, create a box in the background, lock it and set it to be fully custom drawn. I.e. box.ZIndex = 0, box.Locked = true, box.CustomDraw = Customdraw.Full. Also set the box size so that it covers the whole flowchart's DocExtents. Now handle the DrawBox event to paint the background.
Cheers,
andy
Reply #2 - Nov 10th, 2005 at 8:21pm
Hi Stoyan,
thanks for your help... the box in the background should work fine. Thanks for the idea!
Cheers
Andy
