Normal Topic Selection issues/question (Read 2189 times)
David Conroy
Guest
Nov 16th, 2005 at 1:39pm
Ok, we are working on a solution where all chart objects are created programmatically.  So
  • I do not want users to create things with the mouse.
  • I do not want users to be able to move created objects
  • I DO want users to be able to drag the mouse and select multiple objects.
BUT...
If you select the behavior None, you can't do multiselects(even with the Ctrl key, despite that the guide says it works in ALL modes).
If you select the behavior Modify, you can only put one move constraint on a box, so users can still move objects.
Any ideas how to implement this?  Seems as if behavior needs a new choice, SelectOnly.
Re: Selection issues/question
Reply #1 - Nov 16th, 2005 at 1:49pm
Try setting the flowchart's Behavior to Modify and disable all box selection handles so they cant be moved or resized.
In version 3 syntax that looks like :
box.MnpHandlesMask = 0;
And in version 4 :
box.EnabledHandles = Handles.None;
DConroy
Reply #2 - Nov 16th, 2005 at 2:31pm
That worked beautifully, thanks again!
