Normal Topic Custom drawing AnchorPoints (Read 2686 times)
kvds
Dec 6th, 2005 at 2:10pm
I'm drawing the anchorpoints of my Box objects myself, since I want to show some text next to the anchorpoint. However, when the text is too long, the Box object clips it. Is there a way to set the clip rectangle or are there other ways to achieve what i want?
thanks
Re: Custom drawing AnchorPoints
Reply #1 - Dec 6th, 2005 at 2:45pm
The flowchart repaints only a small area around a modified box, and if part of the text gets out of that area it is clipped. I guess we could implement some method to let you increase the repaint area.
Or you could try attaching a locked transparent box to the box that has the anchor points. If the attached box is larger than the main one, you will get a wider area invalidated whe the box is modified.
kvds
Reply #2 - Dec 7th, 2005 at 6:09am
We will try to use the workaround you suggested for now.
However, would it be possible to make AnchorPoints have tooltip text as well? So that when you hover over an anchorpoint, a description pops up.
Reply #3 - Dec 7th, 2005 at 7:08am
That should be easy to implement, we'll add AnchorPoint tooltips in next version.
