Normal Topic WebChart.Net client-side API (Read 2170 times)
Eliseo
Dec 15th, 2005 at 4:53pm
I'm using the embedded FlowChart.Net in a webpage and I want to perform a number of things with it using client-side scripting (Javascript) but the problem is that I don't have a complete list of the available operations.
So far I've been using LoadFromString, BoxesExpandable, etc because those were the only ones that came with the examples.
Re: WebChart.Net client-side API
Reply #1 - Dec 15th, 2005 at 5:08pm
The OBJECT tag lets you embed the full FlowChart.NET WinForms control in a web page, so you can access from JavaScript all methods and properties mentioned in the help file and other samples.
IE6 does not support handling .NET events though, so you can use events only if you create a wrapper user control that implements the event handlers and embed the wrapper control in the web page.
Reply #2 - Dec 15th, 2005 at 5:12pm
Another problem is that IE cannot use .NET value types, e.g. RectangleF and Color. You can use properties of these types only on the server side via the webchart.dll.
