Normal Topic loading flowchart.net.dll from the Internet zone (Read 2387 times)
Dec 20th, 2005 at 8:35am
We've found out that loading a page embedding Flowchart.NET from the Internet zone fails with the default Intenet permission set. That happens because of the recently added HandleArrowKeys property, whose implementation required overriding "Control.IsInputKey". Handling IsInputKey is probably considered a security risk because it can be used to steal the keyboard focus. As a consequence, HandleArrowKeys will be removed from version 4.0.2 of the control. If anyone needs to handle the arrow keys, use this method:
1) create a new class that inherits FlowChart.
2) override the IsInputKey like this:
protected override bool IsInputKey(Keys keyData)
  switch (keyData)
    case Keys.Up:
    case Keys.Down:
    case Keys.Left:
    case Keys.Right:
	return true;
    default:
	return base.IsInputKey(keyData);
Re: loading flowchart.net.dll from the Internet zo
Reply #1 - Dec 20th, 2005 at 8:40am
Until we release version 4.0.2, the control can be loaded in the Internet zone only by changing the Internet zone permission set so it contains unrestricted permissions for "User Interface".
