Normal Topic CopytoClipboard (Read 2515 times)
Kadar
Guest
CopytoClipboard
Dec 30th, 2005 at 7:48pm
I have a big chart displayed in the flowchart activex but when i use flowchart.copytoclipboard
only portion of the image goes to clip board.
Does anyone know how to send the entire image to clip board so that I don't loose anything.
Regards, Kadar
Re: CopytoClipboard
Reply #1 - Jan 2nd, 2006 at 7:10am
If you need to copy the chart data, select all objects in the diagram before calling CopyToClipboard. If you need to copy bitmap data, either set a larger document size using SetDocSize or FitDocToObjects, or  use ImageExportOptions to set what area of the document to be copied.
