Normal Topic Arr.SegmentCount = 3 (Read 2250 times)
Cliven
Guest
Jan 9th, 2006 at 6:42am
Dear Sir/Madam
I'm not able to set the Arr.SegmentCount = 3 in vb.net code.
Example
Arr.Style = ArrowStyle.Cascading
'before segmentcount = 2
'after also = 2
It doesn't occurs any error until u try to move the table which is connected to this arrow.
Error Message
An unhandled exception of type 'System.ArgumentOutOfRangeException' occurred in mscorlib.dll
Additional information: Specified argument was out of the range of valid values.
Thank & best Regard.
Cliven Yong
Re: Arr.SegmentCount = 3
Reply #1 - Jan 9th, 2006 at 9:13am
Dear Mr. Yong ,
What are the original style and number of segment of the arrow before you change them to Cascading/3? Are there any objects attached to the arrow points or segments ? If there are some and the number of arrow points/segments is decreased, you might have to detach them and reattach them again to a point/segment with a smaller index.
Best regards,
