Hot Topic (More than 10 Replies) Serializing AnchorPatterns (Read 6603 times)
Remko
Jan 5th, 2006 at 12:06pm
one quick question, are AnchorPatterns created for a BoxItem serialized with the flowchart ?
Remko
Re: Serializing AnchorPatterns
Reply #1 - Jan 5th, 2006 at 1:03pm
Only pattern's PatternId is saved. When a patternId is loaded from a file, the AnchorPattern with that id must be defined in your application.
Remko
Reply #2 - Jan 5th, 2006 at 1:16pm
Ok,
I guessed as much, but that brings me to the next problem/challenge.
When i try to serialize the Pattern myself with
// stream out the dockingPoints
	  long anchorPoints = m_dockingPoints.GetAnchorPointCount();
	  ar << anchorPoints;
	  for ( long i = 0; i < anchorPoints; i++ ) {
		m_dockingPoints.GetAnchorPoint( i, &x, &y, &in, &out, &mark, &color, &chArrStyle, &arrStyle, &segments );
		ar << x << y << in << out << mark << color;
I am rewarded with a rather undescriptive OleException, any ideas ?.
(a thought just hit me, could it have to do with the VARIANT_BOOL vs. BOOL size problem in MFC wrappers ?)
Remko
Reply #3 - Jan 5th, 2006 at 1:33pm
Is there any HRESULT code mentioned ?
The VARIANT_BOOL vs. BOOL problem happens when overwriting a VARIANT_BOOL value through a BOOL pointer, i.e. writing 4 bytes to 2-bytes memory location . GetAnchorPoint gets VARIANT_BOOL values through BOOL* pointers, writing 2-bytes to 4-bytes memory location, so there should not be a problem with that.
Remko
Reply #4 - Jan 5th, 2006 at 1:45pm
Stepping through the call I found:
Warning: constructing COleException, scode = DISP_E_TYPEMISMATCH ($80020005).
to be complete, the exception is thrown in the GetAnchorPoint method(), so I'm pretty shure it's not the m_dockingPoints being invalid as the GetAnchorPointsCount() yields the expected result.
Remko
Remko
Reply #5 - Jan 5th, 2006 at 2:07pm
Some more info,
after
SCODE sc = m_lpDispatch->Invoke(dwDispID, IID_NULL, 0, wFlags,
&dispparams, pvarResult, &excepInfo, &nArgErr);
nArgErr == 3
which would be the BOOL *in parameter
which is defined as
static BYTE parms[] =
VTS_I4 VTS_PI2 VTS_PI2 VTS_PBOOL VTS_PBOOL VTS_PI4 VTS_PI4 VTS_PBOOL VTS_PI4 VTS_PI2;
i.e. VTS_PBOOL,  in the generated MFC wrappers.
Remko
Reply #6 - Jan 5th, 2006 at 2:10pm
That could be returned by the standard OLE implementation of IDispatch. Try calling the method directly through the VTBL IFlowChart* pointer; that will bypass the IDispatch parameter translation layer. I.e. use the "flowchart'h" included with the control and query for IID_IFlowChart, then call the GetAnchorPoint method using the exact parameter types.
Remko
Reply #7 - Jan 5th, 2006 at 2:32pm
My memory is definitly deteriorating Sad
I just found that I've had the same problem while handling the OnDrawMark event ....  Embarrassed
   IUnknown *unknown = m_dockingPoints.m_lpDispatch;
		IAnchorPattern *pat;
		unknown->QueryInterface( &pat );
		pat->GetAnchorPoint( i,
				     &px,
				     &py,
				     &in,
				     &out,
				     &mark,
				     &color,
				     &changeStyle,
			    &style,
			    &segments );
works just fine.
(that reminds me that there is a problem when you mix the standard flowchart.h and the MFC wrappers, several types get defined in both versions .... minor problem though)
Yet again, thanks for the support,
Remko
Reply #8 - Jan 5th, 2006 at 2:43pm
It seems that GetAnchorPattern method is undocumented and was implemented for internal use - the XmlWriter uses it. So the XmlWriter writes all information related to an anchor pattern, but in binary format only the pattern id is saved.
Remko
Reply #9 - Jan 6th, 2006 at 8:18am
Ok, I allready had a suspicion it might be internal (the function not being mentioned in the docs was a bit of a giveaway Smiley).
But OTOH GetAnchorPoint() is quite usefull when you need to get info about anchorpatterns, so maybe you could add it to the list of feature requests ?.
Reply #10 - Jan 6th, 2006 at 9:19am
Sure, and we'll probably implement some more humane way to get anchor point information, e.g. with and array of AnchorPoint objects that expose their info  as properties.
