Hot Topic (More than 10 Replies) How to create layout dynamicly (Web) (Read 7222 times)
dbapnxf
Jan 16th, 2006 at 6:30pm
I created my boxes but they will not lay out like I would like.  I tried this code but id does not work.
     LayeredLayout ll = new LayeredLayout();
     ll.SplitLayers = true;
     ll.LayerDistance = 50;
     ll.NodeDistance = 60;
     ll.Orientation =
          MindFusion.WebChart.LayoutSystem.Orientation.Vertical;
     ll.Arrange(fc);
Any and all help would be greatly appreciated.
Nick
Re: How to create layout dynamicly (Web)
Reply #1 - Jan 16th, 2006 at 6:46pm
Doesn't that code move the nodes at all, or it moves them to wrong positions ?
dbapnxf
Reply #2 - Jan 16th, 2006 at 6:50pm
I set it to horizontal the first tim and they where ok but I want vertical and I changed it but the nodes stay in the horizontal layout.
Reply #3 - Jan 16th, 2006 at 7:02pm
Are all nodes in the same graph? If the diagram has several graphs, the nodes in each graph will be laid out using vertical layout, but the graphs themselves are just stringed in a single row.
dbapnxf
Reply #4 - Jan 16th, 2006 at 7:42pm
Not that I know of.  If I send you the code do you think you could help me?
Reply #5 - Jan 17th, 2006 at 5:43am
Please send me the diagram data too - use SaveToFile or XmlWriter and email me the saved diagram.
dbapnxf
Reply #6 - Jan 17th, 2006 at 5:46pm
I appreciate all your help, thanks again
dbapnxf
Reply #7 - Jan 18th, 2006 at 3:51pm
Now that I centered all nodes(boxes) the arrows are not in the center and I can not figure how to change them.  I emailed you the JPG to show you what I mean.  Thanks
Reply #8 - Jan 18th, 2006 at 5:39pm
Assign to all boxes an AnchorPattern object that allows one incoming arrow at position (50, 0) and one outgoing arrow at (50, 100). Then the arrows will always go out from / come into exactly the centers of node top and bottom sides.
Another possibility is to explicitly set the positions of arrow.ControlPoints[0] and arrow.ControlPoints[arrow.ControlPoints.Count - 1]. After doing that call arrow.UpdateFromPoints so the arrowhead direction is recalculated.
dbapnxf
Reply #9 - Jan 18th, 2006 at 7:16pm
The following code is how I tried to implement your sugestion but it did not change anything.  What am I doing wrong?
public class ScheduleDisplay : System.Web.UI.Page
     private AnchorPattern ap = new AnchorPattern(new AnchorPoint[]{
new AnchorPoint(50, 0, true, false),
new AnchorPoint(50, 100, false, true)});
     public void buildStartTerm(DataSet dsSchedule)
Box boxStart = fc.CreateBox(0, 0, 100, 50);
boxStart.AnchorPattern = ap;
fc.FitDocToObjects(10);
public void buildBox(DataSet dsSchedule, int i)
Box bx = fc.CreateBox(0,0,200,100);
bx.AnchorPattern = ap;
Reply #10 - Jan 18th, 2006 at 7:30pm
Try setting the layout's Anchoring property to 'Reassign'. The default value is 'Ignore', which makes the layout not use anchor points at all.
dbapnxf
Reply #11 - Jan 18th, 2006 at 9:19pm
Thank you again.  That did it!!
