Normal Topic Pocket Planner - Questions (Read 8197 times)
Amir
Guest
Feb 6th, 2006 at 3:11pm
I would like to know if this component supports both VS.NET 2003 and VS.NET 2005.
Is it possible to make the planner support Right-To-Left and support other languages? I want the ability to change the name of the days to another language, and also move the timetable from the left side to the right side of the screen.
If this isn't technically possible, please tell me if the source code can be easily manipulated to accomplish this task.
Amir
Re: Pocket Planner - Questions
Reply #1 - Feb 7th, 2006 at 11:06am
Thank you for your interest in PocketPlanner.
The dlls installed in the root installation folder are for .NET 1.1 and VS2003. The ones in the 'Assemblies for .NET 2' folder are for .NET 2 and VS2005. We have recently been reported that VS2005 cannot find the design-time dll on some PCs. If you have that problem there, add the PocketPlannerDesign.dll to the Global Assembly Cache.
The component does not support right-to-left layout at this time. We can copy that from the 'big' Planner.NET component for the next PocketPlanner release.
Reply #2 - Feb 7th, 2006 at 11:23am
PocketPlanner gets the day names from the current culture set for the device. You can override that by assigning a new value to the Calendar.DateTimeFormat  property.
racer
Guest
Reply #3 - Mar 30th, 2006 at 6:05am
dont you have a free trial for 30 days so that i can use and test the components
Reply #4 - Mar 30th, 2006 at 9:08am
I guess you already have the trial version since we discussed the Demo sample last several days. When you install the
https://mindfusion.eu/PocketPlannerTrial.zip
package you also get evaluation copies of the PocketPlanner assemblies. You can use these in your own projects, they are not limited in functionality and will never expire.
