Normal Topic TreeExpanded and routing (Read 2704 times)
Vincent Bray
Guest
Feb 16th, 2006 at 6:52am
I have a problem with the TreeExpanded events. I try to route the arrow after expanding the node.
So far only RouteAllArrow was working. But my flowchart is huge and it take a lot of CPU time to reroute all the arrow (plus, only the new one need to be reroute.)
The following code does not work. Do you have any idea about routing only the arrow output of the expanded box ??
Thanks in advance
code sample:
private void ModelChart_TreeExpanded(object sender, MindFusion.FlowChartX.NodeEventArgs e)
this.treeLayout.Arrange(this.ModelChart);
for (int i=0;i<e.Node.OutgoingArrows.Count;i++)
Arrow tempArrow = this.rootNode.OutgoingArrows[i];
tempArrow.AutoRoute = true;
tempArrow.Route();
this.ModelChart.FitDocToObjects(30,true);
Re: TreeExpanded and routing
Reply #1 - Feb 16th, 2006 at 7:26am
The TreeLayout arranges arrows accross the tree levels, is there any specific reason you need them rerouted?
Depending on what you consider parent-to-child direction of links in your tree, you might need to call Route for the incoming node arrows instead of the outgoing ones.
In addition, if you use tables or grouped nodes, you might have to iterate all table rows and their arrows or all subordinate nodes' arrows.
Vincent Bray
Guest
Reply #2 - Feb 16th, 2006 at 7:35am
Thanks for your quick answer  Cheesy
Basically my problem is the following.
I create my all flowchart, then i collapse the first row down the root node.
When i begin to expand node, the treelayout work well and rearrange my node display but some of the outgoing arrow cross node.
I want them to be routed in ordder to avoid crossing nodes but without rerouting all the arrow.
Hope that make sens.
Vincent Bray
Guest
Reply #3 - Feb 16th, 2006 at 7:45am
PS: The auto route option with the "crossing node triger" does not work after i expand a node. But only if i create or/and modeify a node or/and arrow.
Reply #4 - Feb 16th, 2006 at 8:07am
Arrows should not cross nodes after the tree layout, with what TreeLayout settings has that happenned ? Could you  email me your diagram saved in a file so we can test the routing here ?
