Normal Topic Can I invert the move and arrow behaviors? (Read 2554 times)
Alvaro
Guest
Feb 24th, 2006 at 6:26pm
I would like to swap the behavior of the Move and Arrow functionalities for boxes.  The way it is now, I have to click in the middle of the box to move it.  But I can click anywhere else inside it to add an arrow to link it to another box.  I want to invert those two.  Is it possible, and if so how?
Thanks!
Alvaro
Re: Can I invert the move and arrow behaviors?
Reply #1 - Feb 25th, 2006 at 7:34am
Set the HandlesStyle of boxes to 'EasyMove', or set the default value for new boxes like this
fc.BoxHandlesStyle = HandlesStyle.EasyMove;
fc.ModificationStart = ModificationStyle.AutoHandles;
Alvaro
Guest
Reply #2 - Feb 27th, 2006 at 12:43pm
I appreciate the response Stoyan.  However, I just realized that I'm working FlowChartX, the ActiveX control.
The properties you mentioned don't seem to be there, for some reason.  So how would it be done?
Thanks!
Alvaro
Reply #3 - Feb 27th, 2006 at 2:20pm
The correspondent properties in the ActiveX version are called SelStyle and BoxSelStyle. The enum value should be called sstEasyMove.
Alvaro
Guest
Reply #4 - Feb 27th, 2006 at 3:03pm
That worked, thanks!  Smiley
Alvaro
