Normal Topic Multiple objects deletion (Read 2788 times)
JGG
Mar 6th, 2006 at 5:15pm
I have read in a previous thread that FlowChart.NET does not support directly multiple objects deletion. If possible, I would suggest adding a "AllowMultiDel" field to the Selection class to allow this.
Of course, it is possible to do this manually by handling the KeyDown event and calling DeleteObject on each object of the selection, however this does not fire user events, which is kinda inconvenient as it does not differentiate user input from programmatic calls.
Thanks!
JGG
Re: Multiple objects deletion
Reply #1 - Mar 6th, 2006 at 6:19pm
It seems that behaviour is a hangover from the far past - the first versions of the FlowChartX ActiveX component did not support multiple selection at all. I guess the default action should be deleting all selected items; will pass that to our developers.
