Normal Topic Box.Tag property (Read 1303 times)
Mark_Wills
Box.Tag property
Mar 8th, 2006 at 12:51pm
Guys,
If I put a form in the Tag property of a Box instance, which contains a rich text box, and toolbar, do you see a major problem with this?
It makes it easier to display the appropriate form according to the box selected.
Will it break the serialisation functionality of the flowchart object?
Regards
Mark Wills
Re: Box.Tag property
Reply #1 - Mar 8th, 2006 at 1:24pm
That shouldn't be a problem, but probably the tag forms won't be serialized. If you need to serialize the forms, mark the tag class with the [Serializable] attribute and implement the ISerializable interface.
