Normal Topic STrange problem :-) (Read 1782 times)
Mark_Wills
STrange problem :-)
Mar 10th, 2006 at 12:23pm
Hmmm, this is strange...
I have the Flowchart control placed on an MDI parent form, docked, full size.
When my application opens a form (a child of the MDI form) the windows do not appear - I changed the size the Flowchart, and I see that the form is opening up BEHIND the flow chart!! Arrrgh!! Help! How do I get around that problem!
Mark.
Re: STrange problem :-)
Reply #1 - Mar 10th, 2006 at 2:08pm
The same seems to happen if you place other controls in the MdiContainer, e.g. textboxes or buttons. Try putting the flowchart in a MDI child form - you could handle some events to keep the flowchart form behind the other MDI children.
Reply #2 - Mar 10th, 2006 at 2:28pm
The following seems to work, however with some flickering when the flowchart form is clicked:
public Form1()
  // Required for Windows Form Designer support
  InitializeComponent();
  // TODO: Add any constructor code after InitializeComponent call
  flow = new Form2();
  flow.Show();
  flow.MdiParent = this;
  flow.FormBorderStyle = FormBorderStyle.None;
  flow.Bounds = this.ClientRectangle;
Form2 flow;
private void Form1_Resize(object sender, System.EventArgs e)
private void Form1_Move(object sender, System.EventArgs e)
private void menuItem2_Click(object sender, System.EventArgs e)
  Form child = new Form();
  child.MdiParent = this;
  child.Show();
private void Form1_MdiChildActivate(object sender, System.EventArgs e)
  if (this.ActiveMdiChild is Form2)
    foreach (Form f in this.MdiChildren)
     if (!(f is Form2))
       f.Activate();
Form1 is the MDI container, and Form2 contains a docked flowchart.
