Normal Topic ClearAll() (Read 1942 times)
dsmyth
ClearAll()
Mar 13th, 2006 at 11:47am
The ClearAll method of the FlowChart object throws an Index was outside bounds of array error message.
Anyone got a code sample I can use as a replacement. Ta.
Re: ClearAll()
Reply #1 - Mar 13th, 2006 at 12:24pm
Could you save into a file the diagram with which that happens and email it to support@mindfusion.org ?
dsmyth
Re: ClearAll()
Reply #2 - Mar 14th, 2006 at 8:32am
This turned out to be code in the TableDeleted event that caused the index out array bounds.
The ClearAll() method calls the TableDeleted for each table that's cleared from the flowchart. The code in the event referenced a table that no longer existed.
