Normal Topic Disable Arrow Creation (Read 3638 times)
Ganesh Muthuvelu
Guest
Mar 14th, 2006 at 8:45pm
For a box, I do not want any outgoing arrows or incoming arrows. Is there a property setting for this or I have to handle it only in the "ArrowCreating" event ?.
Thanks.
Re: Disable Arrow Creation
Reply #1 - Mar 15th, 2006 at 6:39am
You could set AllowUnanchoredArrows to false and do not assign that box.AnchorPattern. But then all other boxes should have some anchor points defined where arrows could connect.
Ganesh Muthuvelu
Guest
Reply #2 - Mar 15th, 2006 at 6:17pm
May be a Booelan property setting like "AllowIncomingArrows", "AllowOutgoingArrows" could have been more easier than this?.
Setting AllowUnanchoredArrows to False and not assigning a AnchorPattern seems to look like a workaround?.
Ganesh
Reply #3 - Mar 15th, 2006 at 8:06pm
Ok, try this version
https://mindfusion.org/_temp/fcneta.zip
It adds AllowIncomingArrows and AllowOutgoingArrows properties to the Node class.
We haven't tested that much and serialization for the new properties is not implemented yet.
Ganesh Muthuvelu
Guest
Reply #4 - Mar 16th, 2006 at 7:07pm
We will be buying this product (hopefully) in the next couple of days and do you think you will be able to roll these added features in the upcoming version?. if yes, when do you think you will be able to release that official version?
I really need to convince my mgr with these added features and approve this purhcase.
Thanks.
Reply #5 - Mar 16th, 2006 at 7:28pm
We will release version 4.0.4, with these additional properties included, by the end of next week.
Ganesh Muthuvelu
Guest
Reply #6 - Mar 18th, 2006 at 6:34pm
Thanks, I look forward for your release.
