Normal Topic textarea visibility (Read 6787 times)
p.hannah
textarea visibility
Apr 3rd, 2006 at 7:16am
I've got a flowchart, and I'm controlling what the user sees by using the visible attribute.
When I have the following:
http://base.google.com/base_imageq=hand-7809285236146480247&size=6
The result after making all objects and arrow invisible is:
http://base.google.com/base_imageq=hand-5658263955479912637&size=6
p.s. I thought I sent this one in before, but I must have forgotten to press submit...
« Last Edit: Apr 3rd, 2006 at 1:48pm by p.hannah »
Re: textarea viibility
Reply #1 - Apr 3rd, 2006 at 12:27pm
You have posted that one in the FlowChartX board. But I can't see the images neither here nor in the old message ?
p.hannah
Reply #2 - Apr 3rd, 2006 at 12:46pm
damn, must have been late...
Damn, I can see the images on both machines here, what about this url:
http://base.google.com/base/a/pkhannah/1160497/4721554619132693410
if that doesn't get you anywhere, search for 'paul hannah bug' in google base.
Paul.
Reply #3 - Apr 3rd, 2006 at 1:09pm
Do you mean there is some part of the text remaining visible ? Probably the area outside of these boxes is not refreshed, that should be easy to fix.
Reply #4 - Apr 3rd, 2006 at 1:12pm
Now after I have visited base.google.com, I can see the images here too. Strange...
Reply #5 - Apr 3rd, 2006 at 1:36pm
Meanwhile you can use the FlowChart.Invalidate method to repaint everything after changing the visibility of objects.
Re: textarea visibility
Reply #6 - Apr 4th, 2006 at 11:00am
How have you managed to draw text outside the boxes? Is that done with custom drawing, or with ShapeTemplates whose text area is defined outside of the [0..100, 0.100] range? We will fix the latter case. If using custom drawing, you will have to keep text inside the node bounds.
p.hannah
Reply #7 - Apr 5th, 2006 at 1:18am
Stoyo,
The drawing is all done through the text attribute, the text area is defined by the users (who sent me those screenshots, so I can't give you any information about what the bounds have been set to.)
Thanks.
Reply #8 - Apr 5th, 2006 at 12:35pm
That's fixed now, I can send you the dlls if you need the fix urgently. The other stuff should be ready in a couple of days.
