Normal Topic run-time error in arrow.route() (Read 2439 times)
p.hannah
Apr 7th, 2006 at 1:53am
Details below.
Thanks.
Position of error:
case 2:
grid[ptStart.X - 1, ptStart.Y] = 255; <----------------------
// Pull further if possible
if (ptStart.X + 1 < gridCols && elongate)
Relevent watches:
ptStart
{X = 15 Y = -5}
System.Drawing.Point
IsEmpty
false
bool
X
15
int
Y
-5
int
grid
{Dimensions:[200, 113]}
byte[,]
(I can send the contents of this if required...)
Exception Detail:
System.IndexOutOfRangeException was unhandled
  Message="Index was outside the bounds of the array."
  Source="FlowChart.NET"
  StackTrace:
      at MindFusion.FlowChartX.Arrow.doRoute(Boolean force) in C:\Documents and Settings\Paul\My Documents\SysCAD\GUIs\FlowChart.NET\Arrow.cs:line 3173
      at MindFusion.FlowChartX.Arrow.Route() in C:\Documents and Settings\Paul\My Documents\SysCAD\GUIs\FlowChart.NET\Arrow.cs:line 3018
      at SysCAD.Editor.FrmFlowChart.RouteArrow(Object sender, EventArgs e) in C:\Documents and Settings\Paul\My Documents\SysCAD\GUIs\Editor\FlowChart.cs:line 604
      at System.Windows.Forms.MenuItem.OnClick(EventArgs e)
      at System.Windows.Forms.MenuItem.MenuItemData.Execute()
      at System.Windows.Forms.Command.Invoke()
      at System.Windows.Forms.Command.DispatchID(Int32 id)
      at System.Windows.Forms.Control.WmCommand(Message& m)
      at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
      at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNat
iveMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
      at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
      at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
      at System.Windows.Forms.Application.Run(Form mainForm)
      at SysCAD.Editor.Program.Main() in C:\Documents and Settings\Paul\My Documents\SysCAD\GUIs\Editor\Program.cs:line 17
Re: run-time error in arrow.route()
Reply #1 - Apr 7th, 2006 at 10:04am
Ok thank you. Replace the switch there with this version
https://mindfusion.org/_temp/arrow_src.zip
