Normal Topic Box fill colors not correct (Read 6202 times)
Bas
Apr 14th, 2006 at 8:33am
I am using Delphi 2005 and FlowChartX 4.0.1. When I drop a new TFlowChart on my form, and set the BoxFillColor property to clTeal, a box is displayed with the correct color.
When I do the same thing with several other colors, for example clInactiveCaption, the box will always be displayed with a black color.
This goes for fsSolid, fsGradientH and fsGradientV modes.
The same goes for BoxFillColor2, when used as a gradient. The entire box is black.
I hope this can be fixed in a future version.
Re: Box fill colors not correct
Reply #1 - Apr 14th, 2006 at 12:12pm
Hi, We'll look into that next week.
Bas
Reply #2 - Apr 16th, 2006 at 6:46am
Nice, thanks!
Reply #3 - Apr 21st, 2006 at 6:31am
We have tried that with Delphi 6 and all these UI element colors seem to work fine. We don't have Delphi 2005 - could you email us a compiled .exe that displays a flowchart and a button, and upon clicking the button sets fc.BoxFillColor to clInactiveCaption. We will trace through the property setter and see exactly what value is passed to it.
Bas
Reply #4 - Apr 21st, 2006 at 9:17am
I just sent you an email with a demo project, incl. source. One important thing I just noticed is that this bug only occurs in GDI+ mode. In classic everything works fine.
You can test this yourself by launching the Project1.exe, create a box in the Flowchart, and click the button to switch to GDI+ mode.
Hope this helps. If you need anything else please let me know.
Bas
Reply #5 - Apr 25th, 2006 at 5:58am
Hi, were you able to reproduce this behaviour?
Reply #6 - Apr 25th, 2006 at 7:55am
Yes, that constant seems to specify an index in the system color palette, and GDI+ cannot work with such indices directly. We will have to implement lookup for the RGB values of a color in the palette and use them instead of the OLE_COLOR index value.
Reply #7 - Apr 26th, 2006 at 1:54pm
Tough luck with that - the control already uses OleTranslateColor/GetSysColor APIs to get the RGB values for OLE_COLOR system palette indices, which are encoded as 0x800000xx where xx is the index. The UI-color constants in Delphi are in that form, but for some of them those APIs return an E_INVALIDARG error code. Our developers think Delphi probably extends the OLE_COLOR semantics with its own palette implementation, but unfortunately we don't know how to get the actual RGB values from an index in that case. Try getting the actual R/G/B values using some Delphi function and assign them to the BoxFillColor instead of directly assigning the TColor constant.
The problem also happens when using the classic drawing API.
