Very Hot Topic (More than 25 Replies) FlowLayout Exception (Read 16546 times)
jmquinlan
Apr 14th, 2009 at 9:52am
The diagram I was laying out was previously in an AnnealLayout with Striaght / Dynamic Links with no joints in them.
System.ArgumentOutOfRangeException was unhandled
  Message="Index was out of range. Must be non-negative and less than the size of the collection.\r\nParameter name: index"
  Source="mscorlib"
  ParamName="index"
  StackTrace:
       at System.Collections.CollectionBase.System.Collections.IList.get_Item(Int32 index)
       at MindFusion.Diagramming.PointCollection.get_Item(Int32 index)
       at MindFusion.Diagramming.DiagramLink.x5fcd47acc4164137()
       at MindFusion.Diagramming.DiagramLink.xd433eaf1292c9575()
       at MindFusion.Diagramming.DiagramLink.x0d5905a18dc24aa7(Boolean x1c5ff8c3c1ac16ad)
       at MindFusion.Diagramming.DiagramLink.UpdateFromPoints(Boolean updateGroups, Boolean updateSegmentCount)
       at MindFusion.Diagramming.DiagramLink.UpdateFromPoints(Boolean updateGroups)
       at MindFusion.Diagramming.DiagramLink.UpdateFromPoints()
       at MindFusion.Diagramming.Layout.x3462aa19b03aac15.xe47b2712dbae7a09()
       at MindFusion.Diagramming.Layout.x3462aa19b03aac15.x0360c0152e0fc04b(ArrayList x6fa2570084b2ad39)
       at MindFusion.Layout.x0bd7aa907b5c2ae1.xa80296b5ce0aad9d(x82e1bd820ac7ff15 x9fc3ee03a439f6f0, ArrayList xd9cc9787b074c77c)
       at MindFusion.Layout.x0bd7aa907b5c2ae1.x96f3a1e179e5157d(x82e1bd820ac7ff15 x9fc3ee03a439f6f0, Single xd4d7bd59bc0483e3)
       at MindFusion.Layout.xabd66bcda3e8fc57.x8d75079465097c70(x0bd7aa907b5c2ae1 x6b631e0009a9deea, Boolean x4c8d8e849653d454, x01a1fee0f328037a xf4336cad79ab23b5)
       at MindFusion.Layout.xabd66bcda3e8fc57.x0bd7aa907b5c2ae1(Boolean x4c8d8e849653d454)
       at MindFusion.Diagramming.Layout.FlowLayout.BendLinks(Diagram diagram)
       at MindFusion.Diagramming.Layout.FlowLayout.x91cb73cecf8b5941(Diagram x8b62359f01cfd806)
       at MindFusion.Diagramming.Layout.FlowLayout.Arrange(Diagram diagram, DiagramItemCollection items, RectangleF[] laneBorders)
       at MindFusion.Diagramming.Layout.FlowLayout.Arrange(Diagram diagram, DiagramItemCollection items)
       at MindFusion.Diagramming.Layout.Layout.Arrange(Diagram diagram)
       at FlowVisualiser.FlowVisualiser.LayoutAllItems() in C:\Perforce\f1branches\dev\dev1\programming\tools\fe\FlowVisualiser\FlowVisualiser.cs:line 1213
       at FlowVisualiser.FlowVisualiser.LayoutFlowDiagram() in C:\Perforce\f1branches\dev\dev1\programming\tools\fe\FlowVisualiser\FlowVisualiser.cs:line 1240
       at FlowVisualiser.FlowVisualiser.applyToolStripMenuItem1_Click(Object sender, EventArgs e) in C:\Perforce\f1branches\dev\dev1\programming\tools\fe\FlowVisualiser\FlowVisualiser.cs:line 1533
       at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
       at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
       at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
       at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
       at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
       at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
       at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
       at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
       at System.Windows.Forms.ToolStrip.WndProc(Message& m)
       at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
       at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
       at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
       at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
       at System.Windows.Forms.Application.Run(Form mainForm)
       at FlowVisualiser.Program.Main() in C:\Perforce\f1branches\dev\dev1\programming\tools\fe\FlowVisualiser\Program.cs:line 17
       at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
       at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       at System.Threading.ThreadHelper.ThreadStart()
jmquinlan
Re: FlowLayout Exception
Reply #1 - Apr 14th, 2009 at 11:22am
I'm creating a diagram consisting off:
5 ContainerNodes Random Positions
9 ShapeNodes Random Position
26 DiagramLinks connecting these container nodes and shape nodes
note: the container nodes do not contain anything they are just used a representation of internal processing. the links connect to and from the containernodes to the shapenodes.
When I am using an anneal layout the diagram works fine, if I use a flow diagram it breaks.
Reply #2 - Apr 14th, 2009 at 3:26pm
Thank you, our developer will check this tomorrow.
jmquinlan
Reply #3 - Apr 15th, 2009 at 9:39am
Here is the code I am using for the layout using the flow layout, and this code crashes without the diagram having previously been laid out
            public void SetupRoutingOptions(Diagram diagram)
                diagram.RoutingOptions.SetDefaultMode();
                diagram.RoutingOptions.SmartPolylineEnds = true;
                diagram.RoutingOptions.TurnCost = 15;
                diagram.RoutingOptions.CrossingCost = 25;
                diagram.RoutingOptions.LengthCost = 15;
                diagram.RoutingOptions.NodeVicinitySize = 10;
                diagram.RoutingOptions.NodeVicinityCost = 20;
                diagram.RoutingOptions.Anchoring = Anchoring.Keep;
                diagram.RoutingOptions.GridSize = 10;
            public void Setup(Diagram diagram)
                SetupRoutingOptions(diagram);
                this.AutoRoute = true;
                this.HorizontalGroupOffset = 60;
                this.VerticalGroupOffset = 35;
                this.NodeDistance = 10;
                this.Margins = new SizeF(0, 0);
                this.RecreateGraph = true;
                FlowLayoutRules rules = this.LayoutRules;
                rules.PreferredRules = PreferredRules.ConnectorRules;
                rules.NodeRules.GroupStartNodes = "Start";
                rules.NodeRules.GroupEndNodes = "End";
                rules.ConnectorRules.HorizontalBendOrientation = false;
            private void LayoutAllItems(Diagram diagram, DiagramView view)
                diagram.ResizeToFitItems(20);
                this.Arrange(diagram);
                view.ZoomToFit();
                view.ZoomOut();
            public void LayoutVis(Diagram diagram, DiagramView view)
                Setup(diagram);
                LayoutAllItems(diagram, view);
jmquinlan
Reply #4 - Apr 15th, 2009 at 9:46am
I managed to narrow this crash down to these lines of code:
jmquinlan
Reply #5 - Apr 15th, 2009 at 10:59am
infact its literrally this:
and it doesn't matter if I set it to true or false...
regards
jmquinlan
Reply #6 - Apr 15th, 2009 at 11:00am
as a work around just remove from the code
Reply #7 - Apr 15th, 2009 at 12:02pm
Our developer has tried this but could not reproduce the exception. Could you save the diagram as xml file and email it to support@mindfusion.eu?
Reply #8 - Apr 15th, 2009 at 12:07pm
also... should we run anneal layout before that to reproduce the exception?
jmquinlan
Reply #9 - Apr 15th, 2009 at 12:55pm
I was originally getting the exception while changing to flowlayout from anneal, but then I got it when I was just starting the diagram in flow layout.
How do I export the diagram to xml?
jmquinlan
Reply #10 - Apr 15th, 2009 at 2:09pm
okay I've emailed the diagram Smiley
Reply #11 - Apr 15th, 2009 at 3:36pm
we've got it - thanks
Reply #12 - Apr 16th, 2009 at 12:16pm
We still can't reproduce it :-/ After replacing the IDs of your custom classes to load the file, FlowChartShapeNode with std:ShapeNode, FlowChartLink with std:DiagramLink, etc, FlowLayout runs without an exception. Do your custom item classes override any methods of the base classes? Any chance you send us the code for the custom classes?
Also, seems with that setup the layout cannot find any rules to follow, and just bends the links while preserving the node positions, which should not be different from applying OrthogonalRouter.
jmquinlan
Reply #13 - Apr 16th, 2009 at 3:05pm
I will post each of my custom classes here:
        public class FlowBlockContainerNode : MindFusion.Diagramming.ContainerNode
            #region Internal State
            private FlowBlock m_flowBlock;
            #endregion
            #region Constructors
            static FlowBlockContainerNode()
            public FlowBlockContainerNode(Diagram diagram, FlowBlock flowBlock) : base(diagram)
                PointF position = new PointF(m_random.Next(0, 400), m_random.Next(0, 400));
                SizeF size = new SizeF(45, 30);
                this.FlowBlock = flowBlock;
                diagram.Nodes.Add(this);
                this.Move(position.X, position.Y);
                this.Resize(size.Width, size.Height);
                this.MinimumSize = size;
                this.Expanded = false;
                this.AutoShrink = true;
                this.CaptionHeight = 10;
            #endregion
            #region Override Shadow Rendering
            public override void DrawShadow(IGraphics graphics, RenderOptions options)
            #endregion
            #region Accessors
            public FlowBlock FlowBlock
                set
                    m_flowBlock = value;
                    this.Caption = m_flowBlock.ID.ToString();
                get
                    return m_flowBlock;
            #endregion
jmquinlan
Reply #14 - Apr 16th, 2009 at 3:06pm
public class FlowNodeShapeNode : MindFusion.Diagramming.ShapeNode
		private Node m_flowNode;
		private XmlNode m_stateNode = null;
		private eNodeType m_nodeType = eNodeType.standardNode;
		#endregion
		static FlowNodeShapeNode()
		public FlowNodeShapeNode(Diagram diagram, Node flowNode, eNodeType nodeType, XmlDocument statesXml) : base(diagram)
		    SizeF size = new SizeF(40, 10);
		    this.TextFormat.Alignment = StringAlignment.Center;
		    this.NodeType = nodeType;
		    switch (nodeType)
			  case eNodeType.exitPointNode: this.Shape = Shape.FromId("Ellipse");
				this.Resize(20, 20);
				this.LayoutTraits[FlowLayoutTraits.LogicID] = "End";
				break;
			  case eNodeType.standardNode: this.Shape = Shape.FromId("RoundRect");
				this.LayoutTraits[FlowLayoutTraits.LogicID] = "NotSpecified";
				break;
			  case eNodeType.decisionNode: this.Shape = Shape.FromId("Decision");
				this.Resize(45, 20);
				break;
			  case eNodeType.entryPointNode: this.Shape = Shape.FromId("Ellipse");
				this.Text = "Start";
				this.LayoutTraits[FlowLayoutTraits.LogicID] = "Start";
				break;
		    if (flowNode != null)
			  this.FlowNode = flowNode;
			  XmlNode stateNode = null;
			  if (flowNode.State != null)
				stateNode = statesXml.SelectSingleNode("//*[@id='" + flowNode.State + "']");
			  else
				stateNode = statesXml.SelectSingleNode("//*[@id='" + this.Text + "']");
			  if (stateNode != null)
				this.StateNode = stateNode;
		#endregion
		#endregion
		#region Accessors
		public Node FlowNode
		    set
			  m_flowNode = value;
			  this.Text = m_flowNode.ID.ToString();
		    get
			  return m_flowNode;
		public XmlNode StateNode
		    set
			  m_stateNode = value;
			  this.Text = this.Text + Environment.NewLine + "(State = " + m_stateNode.Name + ")";
		    get
			  return m_stateNode;
		public eNodeType NodeType
		    set
			  m_nodeType = value;
			  this.Brush = new MindFusion.Drawing.SolidBrush(Color.White);
			  switch (m_nodeType)
				    this.Pen = new MindFusion.Drawing.Pen(Color.Red);
				    this.TextColor = Color.Red;
				    break;
				    this.Pen = new MindFusion.Drawing.Pen(Color.Orange);
				    this.TextColor = Color.Black;
				    break;
				    this.Pen = new MindFusion.Drawing.Pen(Color.Blue);
				    this.TextColor = Color.Blue;
				    break;
				    this.Pen = new MindFusion.Drawing.Pen(Color.Green);
				    this.TextColor = Color.Green;
				    break;
		    get
			  return m_nodeType;
		#endregion
