Normal Topic Printing and images (Read 1946 times)
MichalLaskowski
Printing and images
Apr 19th, 2006 at 9:52pm
When i try to print my diagram +/- images in table header rows and image in Box are not scaled properly.
Is it a bug or maby its my fault?
Re: Printing and images
Reply #1 - Apr 20th, 2006 at 8:49am
It depends on the MeasureUnit. Pixel and Display units do not work well with printer devices, so if you use any of these, try switching to Millimeter or Point when printing.
MichalLaskowski
Reply #2 - Apr 21st, 2006 at 1:04pm
Could you provide some example how to switch from Pixels to Millimeters with scaling nodes?
Reply #3 - Apr 21st, 2006 at 2:10pm
If you use ScaleToPage before printing or previewing the diagram, the output should look pretty much the same with both pixels and millimeters. Otherwise, you could use graphics.DpiX/Y or Graphics.TransformPoints to find out how many pixels there are in a logical unit, and then scale the print output in that unit so it looks the same size as the on-screen diagram defined in pixels.
