Normal Topic Tooltip for box/arrow in web application (Read 2102 times)
manas
May 16th, 2006 at 11:24am
We have a web application which uses webchart.net.dll. We want tooltip for boxes and arrows.
rootNode = fc.CreateBox(250, 250, 80, 50);
rootNode.ToolTip = "aaaaa";
This doesnt work.
Any help appreciated
Re: Tooltip for box/arrow in web application
Reply #1 - May 16th, 2006 at 12:22pm
The HtmlBuilder creates ALT attributes for the Tooltip property values. That seems to work fine in IE but not in Firefox. Probably Firefox does not display tooltips for the ALT tags or for image map areas, we'll investigate that.
manas
Reply #2 - May 17th, 2006 at 2:56am
We are using IE, but still the tooltip is not visible. It is only visible if we give a hyperlink to the box.
Without hyperlink how is the tooltip visible for boxes?
Reply #3 - May 17th, 2006 at 6:31am
There aren't AREA tags generated for boxes if their Hyperlink is not set. Try setting the hyperlink to "javascript: void (0)". That will generate image map areas but prevent opening another page in the browser if boxes are clicked.
