Normal Topic Selecting a node in web application (Read 2140 times)
manas
May 16th, 2006 at 11:30am
How to select a node in tree in a web application (using webchart.net.dll)?
Re: Selecting a node in web application
Reply #1 - May 16th, 2006 at 12:38pm
You can only select it on the server side, e.g. by setting the node.Hyperlink to a page which changes the selection.
manas
Reply #2 - May 17th, 2006 at 2:59am
We dont want to use hyperlink in the node/box.
How to select node without using hyperlink?
Reply #3 - May 17th, 2006 at 6:37am
You cannot select it without going to the server. If HTML lets you draw frames around image map areas, you could simulate selection by showing an area frame when a box is clicked by setting the hyperlink to a "javascript: showFrame(this)" value. showFrame should be a javascript function that shows or hides the area outlines when the area is clicked.
