Normal Topic Expanding node in web application (Read 1986 times)
manas
May 16th, 2006 at 11:28am
We have drawn a treechart in web application using webchart.net.dll. We want to expand and collapse the nodes of tree.
fc.BoxesExpandable = true;
fc.RecursiveExpand = true;
fc.ExpandButtonPosition = ExpandButtonPosition.OuterTop;
Expand button appears on the boxes, but nothing happens when we click it.
Re: Expanding node in web application
Reply #1 - May 16th, 2006 at 12:29pm
Try setting the HtmlBuilder.ExpandBtnHyperLink property to a page on your server which should process the expand/collapse action. You can get the index or tag of the box which should be expanded by adding {0} or {1} format specifiers to the hyperlink. Then on the server check the box identifier, expand or collapse the affected tree branch and redirect to the diagram page.
manas
Reply #2 - May 17th, 2006 at 2:52am
Is it compulsory to use hyperlink in the box? Is there other way to expand/collapse the nodes without using hyperlink?
Reply #3 - May 17th, 2006 at 6:28am
The webchart library can only generate images on the server side, and it is not a full blown web control (yet), so there is no other way to handle the expand/collapse except setting that hyperlink and handling it on the server side.
